Cómo eliminar System Antivirus 2008
segundopremio
Buenas,
se me ha descargado ese famoso falso antivirus llamado System Antivirus 2008. Me salen pop-ups continuamente y no me aparece en la lista de programas del panel de control para eliminarlo; alguien sabe cómo puedo hacerlo?
Muchas gracias
KiÐ
Hola segundopremio y bienvendio a los foros.
Prueba con el desinstalador del CCleaner.
Sino, con el Your Unistaller!.
O sigue estos manuales:
Eliminar System Antivirus 2008
(en inglés)
Step 1 : Use Windows File Search Tool to Find System Antivirus 2008 Path
   1. Go to Start > Search > All Files or Folders.
   2. In the "All or part of the the file name" section, type in "System Antivirus 2008" file name(s).
   3. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
   4. When Windows finishes your search, hover over the "In Folder" of "System Antivirus 2008", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete System Antivirus 2008 in the following manual removal steps.
      Read more about How to Find System Antivirus 2008 with File Search Tool
Step 2 : Use Windows Task Manager to Remove System Antivirus 2008 Processes
   1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
   2. Click on the "Image Name" button to search for "System Antivirus 2008" process by name.
   3. Select the "System Antivirus 2008" process and click on the "End Process" button to kill it.
   4. Remove the "System Antivirus 2008" processes files:
   5. sav.exe SAV2008Setup[1].exe SystemAntivirus2008.exe
      Read more about How to kill System Antivirus 2008 Processes
Step 3 : Use Registry Editor to Remove System Antivirus 2008 Registry Values
   1. To open the Registry Editor, go to Start > Run > type regedit and then press the "OK" button.
   2. Locate and delete the entry or entries whose data value (in the rightmost column) is the spyware file(s) detected earlier.
   3. To delete "System Antivirus 2008" value, right-click on it and select the "Delete" option.
   4. Locate and delete "System Antivirus 2008" registry entries:
   5. HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Antivirus" = "%ProgramFiles%\System Antivirus 2008\Antvrs.exe" HKEY_LOCAL_MACHINE\Software\Antivirus HKEY_CURRENT_USER\Software\Antivirus
      Read more about How to Remove System Antivirus 2008 Registry Entries
Step 4 : Use Windows Command Prompt to Unregister System Antivirus 2008 DLL Files
   1. To open the Windows Command Prompt, go to Start > Run > type cmd and then click the "OK" button.
   2. Type "cd" in order to change the current directory, press the "space" button, enter the full path to where you believe the System Antivirus 2008 DLL file is located and press the "Enter" button on your keyboard. If you don't know where System Antivirus 2008 DLL file is located, use the "dir" command to display the directory's contents.
   3. To unregister "System Antivirus 2008" DLL file, type in the exact directory path + "regsvr32 /u" + [DLL_NAME] (for example, :C\Spyware-folder\> regsvr32 /u System Antivirus 2008.dll) and press the "Enter" button. A message will pop up that says you successfully unregistered the file.
   4. Search and unregister "System Antivirus 2008" DLL files:
   5. wininet.dll shlwapi.dll
      Read more about How to Remove System Antivirus 2008 DLL Files
Step 5 : Detect and Delete Other System Antivirus 2008 Files
   1. To open the Windows Command Prompt, go to Start > Run > type cmd and then press the "OK" button.
   2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
   3. To change directory, type in "cd name_of_the_folder".
   4. Once you have the file you're looking for type in "del name_of_the_file".
   5. To delete a file in folder, type in "del name_of_the_file".
   6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
   7. Select the "System Antivirus 2008" process and click on the "End Process" button to kill it.
   8. Remove the "System Antivirus 2008" processes files:
   9. sav.exe sav.cpl SAV2008Setup[1].exe wininet.dll shlwapi.dll Uninstall System Antivirus 2008.lnk System Antivirus 2008.lnk SystemAntivirus2008.exe
      Read more about How to Delete Harmful Files
Fuente
o... como indica lobezzno en un post anterior al mismo tema
Descarga el programa HiJackThis y colócalo en una carpeta propia para el HijackThis (por ejemplo una carpeta C:\HijackThis\). Ejecútalo y presiona el botón "Do a system scan and save a logfile"; el programa realizará el escaneo e inmediatamente generará el Log, sólo te pedira el nombre del archivo y su ubicación, puedes simplemente guardarlo así como está. Se abrirá el Bloc de Notas, copia todo el contenido y pégalo como respuesta a este tema.
Para empezar el escaneo de posibles hijackers, clickea en el botón "Scan". Se te presentará una lista con todos los elementos encontrados por el programa .
Comienza un nuevo post y pega el AQUÍ
P.D: Deberás registrarte en la web para poder bajar el Hijackthis ya que tiene un registro distinto al foro.
