KODAKIMG
TOPUN
Buenas tardes.
Me han enviado unas fotos en unos archivos que mi PC no puede abrir. Cuando lo intento me habla del programa "KODAKIMG". Para mi es desconocido. He tratado de localizarlo y bajarmelo pero sin exito.
¿sabeis como puedo descargarme este programa ?
Gracias y un saludo
Caito
Mira esto:
Windows 95 Users
If the Wang Image Viewer does not launch when you open a .TIF email attachment, do the following steps:
Ø Check to see if the viewer is installed on your machine.
o Select Start | Run
o Enter WANGIMG and click OK. If it does not find the program, it will need to be installed.
§ Download IMGINST.EXE and run.
Ø You may need the Windows Installation CD to complete.
Ø Once the viewer is installed, you need to check that it is associated with .TIF files.
o Click here to download a sample single-page .TIF file. Save it to c:\
§ Open My Computer
§ Open the C: drive
§ Highlight sample1.tif by clicking on it once
§ Once is it highlighted, point to it with your cursor and then hold down the Shift key and right click
§ Select ‘Open With…’ from the menu
§ Select WangImg from the list
§ Make sure ‘Always use this program….’box is checked at the bottom of the screen
§ Click OK
§ This will open the image in the Wang Image Viewer
§ Close the image viewer. Test the new association by double-clicking on sample1.tif
Windows 98 Users
If the Kodak Image Viewer does not launch when you open a .TIF email attachment, do the following steps:
o Select Start | Run and enter in Kodakimg. If it is not found, you will need to install.
Ø To install the KodakImg Viewer on your machine
o Select Start | Settings | Control Panel
o Double click on Add/Remove Programs
o Click on the Windows Setup tab
o Click on Accessories
o Click on Details
o Make sure that the Imaging box is checked. If not, click the box so that it is checked.
§ You may need the Windows Installation CD to complete.
Ø Once the viewer has been selected and installed, you need to check that it is associated with .TIF files.
§ Open My Computer
§ Open the C: drive
§ Highlight sample1.tif by clicking it once
§ Once it is highlighted, point to it with your cursor and then hold down the Shift key and right click
§ Select KodakImg from the list
§ Make sure ‘Always use this program…’ box is checked at the bottom of the screen
§ Click OK
Windows NT Users
§ Select Start | Settings | Control Panel
§ Double click on Add/Remove Programs
§ Click on the Windows Setup tab
§ Click on Accessories
§ Click on Details
§ Make sure that the Imaging box is checked. If not, click the box so that it is checked.
Ø You will need to reapply the latest service pack after installation is complete
§ Open My Computer
§ Open the C: drive
§ Click OK
Windows 2000 Users
If the Kodak Image Viewer does not launch when you open a .TIF email attachment….
Ø Select Start | Run
Ø Enter Kodakimg
If the program is found, you will need to check the association for .TIF files.
Ø Click here to download a sample single-page .TIF file. Save it to c:\
§ Open My Computer
§ Open the C: drive
§ Select Kodak Image from the list
§ Click OK
§ This will open the image in the Kodak Image Viewer
Windows XP Users
Windows XP comes with a built-in image file viewer named 'Windows Picture and Fax viewer'. There is a chance that TIF files have been associated with a different program on your PC. To correct this, perform the following steps:
§ Open My Computer
§ Open the C: drive
§ Select 'Windows Picture and Fax Viewer' from the list
§ Click OK
Macintosh Users
Please note that a third-party Group 4 TIF file viewer may have to be obtained and installed on your Mac before you can view TIF files.
One freeware product that we have tested can be found here:NIH Image Home Page
Viewing .TIF files with Image Viewer
o To move from page to page, you can either use the Page menu or click on the ® arrow to go to the next page or the ¬ arrow to return to a previous page (if multiple pages).
o To enlarge view, you can either use the Zoom menu or the magnifying glasses to increase or decrease size.
Printing from Windows 95 and Windows 98
o Open .TIF file
o Select File | Print
o Click on Options button and change Print Format from the default of ‘Fit to Page’ to ‘Actual Size’.
o Click on OK (You will now return back to the print screen)
o Click on Print
You should only have to do this one time.
Saludos Caito
